![](images/pix.gif) |
![das Sülzkotlett](images/userbilder/user244361)
![Forenprofessor](images/forum/special/screwdriver_rank_5.gif) Beiträge: 2735
User seit 01.01.2008
![geprüftes Mitglied](images/geprueft12.gif) | Geschrieben am 23.05.2003 um 16:52 Uhr
| Jordan,
I've doublechecked with a couple of people in the chatroom and the real issue which prevents us from providing an answer to you is we're not sure what a 'rear camber kit' means in German.
Perhaps one of our evening readers is more into the aftermarket vocabulary than we are and can give us a hint in German, or you try to explain what a 'rear camber' means with some easy words for us damn ignorants.
Thanks,
Michael | Antworten
![X-T-C](images/userbilder/user115182)
![Forenabiturient](images/forum/special/screwdriver_rank2_5.gif) Beiträge: 894
![](images/forum/special/screwdriver_rank5_0.gif) User existiert nicht mehr bei MBSLK.de | Geschrieben am 23.05.2003 um 18:38 Uhr
Micha aus Heidelberg schrieb:
Jordan,
Thanks,
Michael
A "rear camber kit" is a kit to re-align the angle of the wheels after you've lowered your car. Some cars have this kind of adjustment, in other ones you have to buy, if exists, a kit to allow this operation.
If you lower your car, looking it from behind, you will see wheels in this position /--- and if you re-align them they should look like this |---|
This is to prevent quick tires wear.
Giordano | Antworten
![geprüftes Mitglied](images/geprueft12.gif) | Geschrieben am 23.05.2003 um 20:01 Uhr
| Hi Giordano,
thanks to your and Werner's explanation I got it. The answer is: I have not seen this device for the SLK yet - what makes me believe you don't need it on a lowered SLK, due to the special construction (perhaps due to the separated spring / shock absorber units) of the suspension elements.
Have you already lowered your SLK? If not, try that first, to be honest I have not seen that /--- effect to a prominent extend on any of the SLKs in the community. I'm almost sure you won't need that kit.
Pending on the model year of your car, you can improve esp. early SLKs angainst nick & roll movements with anti roll kits, but that was not the original content of your question.
Hope that helps and perhaps someone else can provide additional input -
Michael | Antworten
![](images/forum/special/screwdriver_rank5_0.gif) User existiert nicht mehr bei MBSLK.de | Geschrieben am 24.05.2003 um 12:04 Uhr
Hi Giordano,
Michael
Yes, I've already lowered it and this is how it looks.
Here is the angled rear wheels I was talking about.
I had to change right wheel with left wheel on the rear axle, due to disuniform tire wearing.
![Forenquartaner](images/forum/special/screwdriver_rank3_3.gif) Beiträge: 147
![Forenquintaner](images/forum/special/screwdriver_rank3_2.gif) Beiträge: 85
User seit 07.04.2003
| Geschrieben am 26.05.2003 um 08:59 Uhr
swab schrieb:
<font color='#AB2929'>[ Beitrag wurde zuletzt editiert von swab am 25.05.2003 um 20:40 Uhr ]</font>
Hi !
http://www.k-mac.com.au/makes/merc.htm
They have a rear camber/toe kit for Mercedes R170 -- $320 US.
Although, I must say, that I don't have the slightest clue how that might work with that 5 link suspension called Raumlenker-Hinterachse.
Ciao. Sven.
Hubraum ist durch nichts zu ersetzen -- außer durch einen Kompressor
Hi Sven
Da hast du ja was ganz tolles gefunden
Da mein negativer Sturz an der HA nach dem jetzigen Fahrwerk bei -7 Grad ist das echt die Lösung.
Danke
Ich habs mir mal bestellt, wenns da ist und eingbaut ist werd ich mal über die Erfahrungen posten
LG Chris
keep the wheels burning | Antworten
E-Mail an clehr Moderatoren-Team informieren Themen-Abo bestellen |
