Tipps und Technik R170 » » Thema: Kompressor random failure
Gehe zu Seite: ( 1 | 2 | 3 | 4 | 5 | 6 )
User seit 25.12.2015
 Geschrieben am 25.12.2015 um 12:43 Uhr
New here on the forum and since I do no speak German I write in English if that is ok?
To my satisfaction I drive a fantastic 230 kompressor pre facelift ...
There seems to be a problem with my compressor clutch or the command for the clutch ...
When I rev the engine the clutch engages perfectly just above 2000 rpm.
However when I rise the rpm to approx 3000 rpm and keep it there the clutch switches of and on randomly.
It clicks on and of with an interval of +/- 2 to 3 seconds ...
It does the same when driving the car and that is extremely anoying!
Does any one of you had the same problem?
Looking forward to some answer ... Thank you!
  E-Mail an Koen    Bobby Moderatoren-Team informieren    Themen-Abo Themen-Abo bestellen
   UC
User seit 27.06.2015
 Geschrieben am 25.12.2015 um 13:10 Uhr
Hy Koen, perhaps you can look here: http://www.slkworld.com/united-kingdom-region/
UC
320, automatic, schwarz-siam-beige AIO-Modul
Pioneer AVH x7700 bt / Avic-f260
Das Überflüssige ist eine sehr notwendige Sache (Voltaire)
http://www.energieprojekt.biz
  E-Mail an UC    Bobby Moderatoren-Team informieren    Themen-Abo Themen-Abo bestellen
 Geschrieben am 25.12.2015 um 13:15 Uhr
Thank you for the quick answer!
I wil register at the UK forum also but I was told that there are some real specialists over here so that is the main reason I asked the question on this forum ...
Regards ...
 Geschrieben am 25.12.2015 um 13:33 Uhr
Hi koen
Your description sounds to mee like it would be an elektrical problem. You should check the K40 Overload Relay, maybe a faulty solder joint will cause the problem.
Check this to get more informations:
http://tinyurl.com/ntzhb2y
Kind Regards, Christoph
Mercedes Slk 200 K mit üblichem Schnickschnack, BMW 316ti Compact ohne Gimmicks
   Norberator
User seit 27.03.2011
 Geschrieben am 25.12.2015 um 13:36 Uhr
Good afternoon and Merry Christmas Koen.
Although you can't speak German, can you read and understand the given fix desciptions in German language ?
A good number of supercharger failures are based on an oily air mass sensor and/or "cold" soldering spots in the K40 steering relais. Did you already check these failure sources ?
Best regards Norbert
  E-Mail an Norberator    Bobby Moderatoren-Team informieren    Themen-Abo Themen-Abo bestellen
 Geschrieben am 25.12.2015 um 14:30 Uhr
Hello,
I did take out the k40 relais unit and gave it a quick visual inspection ...
At first sight all connections seemed okay but I did not check under a magnifying glass.
Should I do some resoldering ... just in case?
Wicht one is the overboost relais?
The air flow sensor is not oily and it was replaced a year ago with an original Bosch ...
The car did recently get a larger cranckshaftpulley and a software upgrade from a German specialist ... At first it ran perfectly ... And it is fast!!
I also put in a 4 bar fuel pressure regulator and from that moment on the clutch problem seemed more manifest ...
Is there a possibility that the switching of is caused by some electronic measurment?
Has anyone ever fixed the clutch so there is constant kompressor boost?
 Geschrieben am 25.12.2015 um 14:33 Uhr
I think I can understand what is written in German but to me it is difficult to use the search function because I do not know the right German words to describe the problem I am looking for!
It is really fantastic you guys answering in English!
Thank you so much!
   kauba1
 Geschrieben am 25.12.2015 um 22:09 Uhr
Mit dem Stichwort: 'Magnetkupplung fixiert' fand ich:
http://tinyurl.com/qcuqnwg Insbesondere der Beitrag von Ritschi p.4 beschreibt speziell, wonach du suchst. Viel Erfolg! Dieter.
 Geschrieben am 26.12.2015 um 10:51 Uhr
Hi Koen
You could fix the clutch permanently with a few screws, but that would not be an professional solution. The clutch will run permanently, and you will gain a constant compressor boost but the noise of the engine will increase. I guess that your 4 bar fuel pressure regulator cause the problem. I do not understand why you had done that? Whats the reason?
Regards Christoph
   convertible
User seit 03.05.2004
 Geschrieben am 26.12.2015 um 11:01 Uhr
Hi Coen,
Merry Christmas to you and welcome on board.
The problem that yr supercharger runs into failure might be a voltage overload on the MAF (max 5 Volt) caused by yr pulley arrangement leading to overboost.
You can "clamp" the voltage with a diode. So it will never go over 4.8v (if indeed this is the problem).
So in high boost conditions every voltage above 4,8 Volt will be sent to ground
Beste Grüße
SLC 230 PreFL
mbslk.de ... The SLK-CommunityAnonym  :1268
mbslk.de ... The SLK-Community27.433.909
Ja, habe ich
Ja, mache ich
